Thanks, Curtis. That is a good site with plenty of interesting info..... everything from this bit on LIPOs from HK, to Matt
Hall dipping his wheels in the water while racing in Ontario, to dealing with the cloned Spektrum receivers. Hmmm... I need to order more batteries, so I'm not sure what the best thing to do is. From what I've read, if you keep your battery size low, below 2200 mAh, you may get one or two past the detection. I may try that route, just to get a couple more at least.
AC
after edit.. Thanks for the correction, Bill! I fixed my mistake so that it wouldn't be forever recorded on the Internet.
