Large format printing
I want to print a set of plans from PDF that are 24 x 36. I can do it as a tiled print on 8.5 x 14 and tape the sheets together, but they don't always line up well. Has anyone used the Staples printing service? It's only 3.99 for that size, but I've heard they don't always get it the right size which makes the scale incorrect.
Re: Large format printing
KKP on Isley Ave. in Dartmouth (formerly owned by our own Chris Dean as KwickKopy) is first class at good rates. I had all my geological maps done by them. https://dartmouth.kkpcanada.ca/
Ask for Myrna - she's top notch. All prints exactly to scale.
Adobe Acrobat reader has the option to print cut marks. That makes it easier to align the prints.
File | Print | Poster | Select Cut marks Then you can specify the distance to edge / overlap.
I try to print the portion of the drawing, that has the scale in it, first. This allows me to confirm that the size is correct. You can tweak it a bit with the % scale factor if it is under size or over size.
