Lucky me, or maybe not
News related to anything RC
the-mailman
Unread post by the-mailman » Mon Jul 08, 2019 11:20 pm
Last fall I bought a used Hubsan 501s quadcopter. It works really good and has lots of cool features, but I couldn't get much range before the return to home would kick in. Well, last week I fortunately broke the hinge joint on the 2.4 GHz antenna. I know how that sounds so I'll explain why it was good. When I unscrewed the antenna from the transmitter I discovered that the antenna had a RP-SMA male connector and the connector on the transmitter was a SMA female. So, neither part had the pin to make a physical connection between the two. No wonder I had such limited range. The antenna was doing little to nothing.
Now, you'd think this would be an easy fix. Just buy a new antenna with a SMA male connector. Since the antenna modification is an after market add-on I can't get one from Hubsan. MSC had nothing, Jentronics couldn't even order one, and none of the WiFI routers I have had the right connection either. So for a temporary fix, I took one of my WIFI router antennas and used some steel craft wire to create the pin to connect the antenna to the transmitter. The pin was a tight fit so I hope it will be a good connection. It's too small to solder anyway. I can't try a long range flight until I go to the field, but hopefully it will work while I search for the correct replacement.
waxman
Re: Lucky me, or maybe not
Unread post by waxman » Tue Jul 09, 2019 9:05 am
You can find lots of SMA and RP-SMA connectors and adapters at Banggood.
https://www.banggood.com/search/sma-connectors.html
John Liddard
the-mailman
Unread post by the-mailman » Tue Jul 09, 2019 7:23 pm
Thanks, an adapter would do the trick. I'll have a look.
