http://vimeo.com/62015113
Inverted Multirotor Flight
- waxman
Re: Inverted Multirotor Flight
W-O-W...!
Great stuf John, if you want to go this route, I'll bring the vid camera and a garbage bag...!
- waxman
If start trying some of those flight maneuvers I think we'd need a garbage bucket, not a bag.retiredVTT wrote:W-O-W...!
John Liddard
- MarkL
Going inverted is easy, its the getting it upright again that's the hard part
There is no one that can outfly warthox, he is a robot.
It pretty impressive when you consider none of the inverted stuff is managed by the flight controller. Its a normal controller, he is just managing the motor direction much like a CP heli with neutral and center stick. And using his custom made props which are basically normal CF props he flattened so they would run better in reverse.
