Often plans show a servo hot melt glued into the foam structure. It is quick and easy, until it has to be removed to replace a broken gear.
A possible solution is the 3D printed servo mounting frame. These are just a frame with screw mounting holes. You glue the frame in the foam and then screw the servo into the frame
Some frames and boxes are here
https://www.thingiverse.com/thing:533596
https://www.thingiverse.com/thing:3624009
https://www.thingiverse.com/thing:1066457
https://www.thingiverse.com/thing:1066475
https://www.thingiverse.com/thing:4711572
https://www.thingiverse.com/thing:4704031
Servo Frames for Foamies
