looking to borrow a YEP ESC Programming card for a day.
A place for info or problems concerning Transmitters, Receivers or Servos.
KevinM
Unread post by KevinM » Tue Aug 02, 2022 4:26 pm
Anyone have a programming card for a YEP ESC? I have an 40Amp YEP ESC that is in Heli mode (slow spool up on throttle) and can't change it to ACRO without a programming card. I tried the Transmitter Throttle method of programming to no avail. You have to have the programming card to change states. There is one available on Hobby King for $9.03 Cdn, I was going to buy but ....shipping is just under $52.00 ...NOPE!
Just need to borrow the card for a day.
Kevin
The secret of flight is to aim at the ground and MISS
Re: looking to borrow a YEP ESC Programming card for a day.
Unread post by retiredVTT » Tue Aug 02, 2022 5:38 pm
I'll check and let you know, Kevin..
Unread post by retiredVTT » Tue Aug 02, 2022 6:15 pm
Kevin...the word is "Yup, I have a Yep programming card..!" Do you have the instructions to use this card....they appear to be complicated enough that you better figure on having it for TWO days..don't worry the rental fee will be the same right up to five days..then it gets real pricey..!
For some unknown reason my instruction sheet is titled YGE ProgCard 2 - Programming Card.
I'll print off a copy for you.
I'm at 153 Millrun Crescent, Bedford ..902835-1279
KevinM
Unread post by KevinM » Tue Aug 02, 2022 6:56 pm
Bill,
will you be around tomorrow? I have an X-Ray appt at 1pm at Cobiquid Hospital and will be able to drop by before or after the appt. I have downloaded a youtube video on the card and have watched it several times. Doesn't look too complicated.This is not the first ESC I've programmed but it is the first using a programming card. I've always used the throttle method.
Thanks so much, Let me know what time works for you.
Kevin
Unread post by retiredVTT » Tue Aug 02, 2022 8:02 pm
Ok Kevin, maybe you should come by before your appt, say 12:15 since you never really know how long these appts take.
KevinM
Unread post by KevinM » Tue Aug 02, 2022 9:33 pm
Ok Bill,
12:15 it is, see you then. you are only a 10 min drive from my place.
Kevin
Unread post by retiredVTT » Tue Aug 02, 2022 9:37 pm
Ok Kevin, I'll also pay my SRCF dues for this year, hope to get out there in the coming weeks.
KevinM
Unread post by KevinM » Wed Aug 03, 2022 10:24 am
good you mentioned this ....I'll bring the club bag with me. that way I can give you a receipt on the spot.
Kevin
KevinM
Unread post by KevinM » Wed Aug 03, 2022 1:36 pm
Thanks soo Much Bill,
Literally took me 2 minutes to program the ESC.
Works great now.
Thanks again. I'll phone you to let you know when I'm returning the programmer.
Unread post by retiredVTT » Wed Aug 03, 2022 11:04 pm
Glad it all worked out for you ...and glad to get my SRCF paperwork completed.
