DX 7 Battery??
timberman
DX 7 Battery??
Unread post by timberman » Mon Mar 18, 2013 9:19 am
Does anyone use the older DX7 with lipo or life batteries in it ? Is this possible?
I'm thinking of replacing my old nimh in my DX7.
thanks
Dennis
Re: DX 7 Battery??
Unread post by AndrewS » Mon Mar 18, 2013 9:45 am
I use Life 3s in my JR9303 with no troubles.
timberman
Re: DX 7 Battery??
Unread post by timberman » Tue Mar 19, 2013 9:00 am
Do you have to change the battery alarm voltage on the radio for life battery? I've read people have to for lipos.
Re: DX 7 Battery??
Unread post by AndrewS » Tue Mar 19, 2013 10:27 am
I haven't. Full voltage is about the same as the 8cell that comes with it.
Don't charge it in the radio.
Re: DX 7 Battery??
Unread post by astroflyer » Tue Mar 19, 2013 10:55 am
Does the dx7 have an option to change voltage?? the dx7s does, only because the nimh pack is only four cells.
I'm assuming your dx7 has a standard eight cell nimh pack, not an eight cell flat pack. if so get a three cell lipo (hk has one that fits transmitters) and add a diode in the line (inooo4) I think is the number from radio shack) to drop the voltage about one volt. you could used two diodes which would then make your voltage meter pretty accurate.
I use one diode with the hk lipo in my futaba radios with excellent results and charge when the voltage gets to near nine volts. mostly i get bored waiting for it to get that low and charge about once a month. lol
timberman
Re: DX 7 Battery??
Unread post by timberman » Tue Mar 19, 2013 5:58 pm
Thanks for the help , think I'm going to get a life battery . Seen a video on how to change it for DX7 if using a lipo
Dennis
Re: DX 7 Battery??
Unread post by AndrewS » Tue Mar 19, 2013 6:50 pm
This is the Life I use
http://www.hobbyking.com/hobbyking/stor ... duct=14076
It will plug straight into your Dx7 using the same plug as the stock unit. They charge through the balance tab just like a normal lipo.
Al is right... They last a lot longer than the night.
