I've lost my mind... it's all Bill's fault!
- yorcram
Re: I've lost my mind... it's all Bill's fault!
Hmm, and poor Andrew is still waiting on his....
Plane Crazey
- Enforcer
Yes, I was just thinking of poor Andrew and his Spit... as I was sitting here drooling over mine!
Sorry Andrew, I can't resist poking a bit of fun. I truly am sorry tough that your Spit has not arrived yet. If you want, you can come over to my house and look at mine while you wait! But don't touch!!!
Ouch...that one was a low blow..!
- Enforcer
Andrew knows I'm kidding. Right Andrew? You will appreciate it that much more when it does arrive.
Murray, I'm reading through the Hyperion Spitfire thread, making notes of what is being used....I'll make a list here as I read on...
..for grass increase the wheel size to 2.25 inches...Dubro Wheels #225SL ..this requires increasing the retract wheel wells in the wing.
..50 amp OPTO esc
small receiver pack, could use 2S lipo with ubec ..or straight 4.8 vt nicad about 650-1000mah in size.
..Waypoint retract servo 150MGR
I'll add more later..
..50 amp OPTO esc
I'm just not going to tell you when it arrives... so there!
- yorcram
You will.... it would be hard not to show it off.
Plane Crazey
- Enforcer
Thanks Bill!retiredVTT wrote:Murray, I'm reading through the Hyperion Spitfire thread, making notes of what is being used....I'll make a list here as I read on...
..50 amp OPTO esc
I purchased the suggested "Power Pack" with this plane. This includes a Hyperion HP-Z3025-08T 970 kv motor , a Hyperion 50A ESC with built in "Cool" 4A/5V BEC. This ESC will accept 2-6 cell Lipos. If you do use a 5 or 6 cell Lipo, you have to disconnect the on board BEC and add a separate one. So, I am assuming that I won't actually need a separate BEC, since I will probably stick to 3 or 4 cell batteries with a C rating of 25 (again, a suggested C rating). The last item in the Power Pack is a Hyperion 50XL prop adapter.
The manual that came with the plane, also suggests the size and type of servos to use. It does not suggest a particular manufacturer though. The manual also states that a prop diameter of 10 be used, with a pitch of 7 to 10. It says to start with a 10x7 E (no brand suggested but I assume APC?).
- Enforcer
Here's the servos the manual suggests...
4 Micro/Mini 13g to 25g in weight - digital with metal gears (mounts are sized 13 x 26.5 mm)
retract MGR servo highly recommended for ease of installation and proper operation.
Oh, and I lied! It suggest using "their" brand of digital servos (what else!), and an Atlas USB Programmer for HP Digital Servos.
Here is the battery suggested...
3200 to 4200, 20 to 30C, 3S lipo. (I have 3200 and 5000, 15C, 3 Cell batteries that should be OK for now??? Yes? NO?)
So, I guess all I really need are batteries, servos, Rx, and some props. Could you give me any suggestion/thoughts about digital servos with metal gears to use?
Yes..your 3S packs will be ok for now...4S will make her perform though instead of just fly..!
As stated before I'm not big yet on digital servos and still like the HS85mg's or the slightly smaller HS65mg's...both excellent servos at a decent price.
You seem to have the other stuff covered...one way to disconnect that red wire in the esc while still being able to use the esc later is to connect a short extension to the receiver lead of the esc and cut the wire in the cheap extension..!
A lot of talk in the thread about the retract servo ...not sure if you know this but a "retract servo" is not a proportional servo, but instead is a "full travel servo"...when you flip the gear switch on the radio, the servo makes it's full travel. These servos are geared extra heavy. One guy wondered why he could not move this servo by hand (which is a bad practice with any servo) and was told by others that it was not defective...just geared heavy.
Anyway you seem to be on top of this....it will be nice to see it, not too many fiberglas fuselages around Shannon..!
