TIPS and PROBLEM SOLUTIONS for RC FLYERS
Re: TIPS and PROBLEM SOLUTIONS for RC FLYERS
Unread post by retiredVTT » Wed Mar 11, 2009 10:19 am
I saw a "new Gorilla glue" at CTC the other day.
It's a "Super Glue" and says you position the parts for 30 seconds and that's it.
It's clear, reasonable thick, $5.98 for a one ounce bottle, is NOT a polyurethane foaming glue.
But it does not say c/a anywhere on the bottle either.
Says it's good for metal, wood, plastic, does not mention foam.
Guess it will have to be tried on foam.
Ghost Flyer
Unread post by Ghost Flyer » Thu Mar 19, 2009 9:19 pm
This collection of links and information is simply terrific. The article, "Selecting an Electric Powersystem", by Bill Stevens of StevensAero, is just what I've been looking for. As a newbie, this thread is a big help. Thank you for posting all these, Bill!
Andrew C.
Unread post by retiredVTT » Thu Apr 09, 2009 12:56 pm
Sometimes you read a tip that is SO simple...you think..Jeez, why didn't I think of that..! Well, maybe because I have not faced this problem ..YET..!
We all know that Nylon screws (we like to call them Bolts) are used to secure landing gear with the idea that they will break off instead of the entire bottom gear plate ripping out on a rough landing. My S/A Edge even has the motor mount cage fastened to the fuselage front with Nylon bolts.
So here's the tip ...when the bolts break off...
"heat the end of a screwdriver and push it into the remaining Nylon stump and let it melt a slot."
Presto, back the bolt out..!
See what I mean...Simple..!
Unread post by retiredVTT » Sat Jul 04, 2009 7:18 pm
Another link that allows you to compare motor "Kv" values with the respective "correct prop sizes" ....info like this will help prevent motor burn outs due to incorrect prop sizing which leads to excessive amp draw and the letting out of that magic smoke..!
http://www.skyhobbies.com.sg/Brushless_ ... YPOINT.htm
Unread post by retiredVTT » Tue Jul 21, 2009 1:21 am
Just came across this method of attaching a tailwheel to the rudder.
Takes the strain off the servo...but allows the wheel to track with the rudder.
lawndart
Unread post by lawndart » Mon Aug 24, 2009 2:41 pm
Cutting and soldering motor wires
On some motors -- Towerpro CDrom motors, for instance -- the wires exiting the motor are extensions of the copper windings. This means the wire itself has a varnish coating that prevents solder from adhering. As a result, if you want to shorten the wires you won't be able to solder them to new connectors or the ESC wires without removing the varnish.
Here's a trick I learned from a guy on RCGroups: heat the varnished wire on top of an Aspirin tablet with your soldering iron tip. The Aspirin will melt, creating a syrup of acetylsalicylic acid that dissolves the varnish. Don't inhale. With the wires still hot, removed them from the Aspirin goop and immediately add solder. Voila: perfectly tinned.
Dave
Unread post by retiredVTT » Mon Aug 24, 2009 11:56 pm
Very good tip (Dr.) Dave ...thanks..! (trying to remove that varnish usually results in breaking the wire)
Not any more though..!
Unread post by retiredVTT » Tue Aug 25, 2009 12:50 am
CORROSION X..is a product developed for the aircraft industry to fight corrosion and works well to waterproof our electronic assets in the models we build.
I have waterproofed servos by removing the bottom of the case, submerging the servo , letting it drip, then reassembling the case. Servo is also quieter now as it's well lubed.
Others have dipped esc's and receivers in this product before flying off water.
So where do you get it...in Canada..?
here,
http://www.avtechcanada.com/home.html
AvTech International Inc.
5491 Quartermain Cr.,
Mississauga, ONT.
ph. 1-416-888-7575
Enforcer
Unread post by Enforcer » Wed Sep 09, 2009 7:19 pm
Beginner Tip: Choose your solder wisely.
I had been using solder previously, that came with a basic 25 watt soldering gun I bought several years ago, and that solder worked great. When that ran out a few months ago, I picked up some solder from Circuit City. It was labeled "Lead-Free Rosin Core Solder 1.2 mm". I found it very hard to work with, and now, two months later, some of the wires I soldered are letting go. When this happens, you tend to loose control of your plane... for obvious reasons!!!
Being a newbie, I did not know that this stuff was not the same as the stuff I had been using. I should have picked up some "thinner, 60/40". I have some of that now!
“My philosophy, like color television, is all there in black and white”
Unread post by retiredVTT » Tue Sep 15, 2009 5:30 pm
Another STEERABLE TAILWHEEL INSTALLATION with PICTURES..!
http://www.rcgroups.com/forums/showpost ... stcount=12
