SALE PENDING ** Big Heli Motor for Sale
Got something to sell or trade?
Unread post by retiredVTT » Thu Nov 26, 2020 4:42 pm
This is a new Hyperion HS4020-910 Motor that was designed for use in a large Helicopter, something with around 500mm blades.
As the pictures show it has a long protruding shaft up front, and also is to be "back mounted" which could be a problem if it was used in a plane.
The specs are as follows: KV is 910, can operate from 8 cells, continuous amp draw is 65 amps, continuous wattage is 1820, maximum current is 87 amps, maximum watts is 2455, weight is 284 grams (10 ounces), shaft is 5mm.
Xmas price is $50.00
Ivan
Re: Big Heli Motor for Sale
Unread post by Ivan » Thu Nov 26, 2020 5:43 pm
bill do you have any 1250kv to 1400kv motors laying around that will take 3-4s
trevor
Unread post by trevor » Thu Nov 26, 2020 6:31 pm
Bill I will take this. Just need to get back to Nova Scotia to pick it up
trevor
Unread post by trevor » Thu Nov 26, 2020 8:10 pm
Unread post by retiredVTT » Thu Nov 26, 2020 8:14 pm
Ok Trevor, Let me know when your back, and we will meet.
Unread post by retiredVTT » Thu Nov 26, 2020 8:31 pm
Ivan, I need to know what amperage you want to draw.....and how heavy is the item it's going into. Like do you need 300 watts or 600watts.
trevor
Unread post by trevor » Fri Nov 27, 2020 7:50 am
Thanks Bill. Most likely next weekend due to covid restrictions. But I'm desperate for that exact motor
Re: SALE PENDING ** Big Heli Motor for Sale
Unread post by retiredVTT » Fri Nov 27, 2020 1:00 pm
10/4 Trevor ...sale is pending, no rush...!
Ivan
Unread post by Ivan » Fri Nov 27, 2020 5:43 pm
not sure about the watts but nothing that pulls more the 40amp look for something with low amp as i built a few lithi ion packs if you could send me a link to the motors you have i could look at the specs
Unread post by retiredVTT » Fri Nov 27, 2020 9:55 pm
Ok Ivan, 40 amps on 4S will give you around 600 watts and on 3S about 470 watts. That should be good for a 3.5 to 4 lb plane so now I have something to go on. I'll have a look and get back to you.
