Soldering Job
Got something to sell or trade?
Ivan
Soldering Job
Unread post by Ivan » Sat Apr 04, 2020 5:46 pm
any one up for a soldering job i dont mind paying im not in a rush and i can drop it off and pick it up
wildblue30
Re: Soldering Job
Unread post by wildblue30 » Sat Apr 04, 2020 6:02 pm
Ivan,
What do you need soldered?
MAAC 85077
Tarot 450 Pro V2 FBL DFC, H-King Voltigeur MkII, Durafly Tundra (Blue/Red), BAe Hawk 70mm EDF, H-King Wargo MX2, XK A430 UMX, UMX Timber, Blade mcPx BL2
Transmitter: OrangeRX TX6i
Ivan
Re: Soldering Job
Unread post by Ivan » Sat Apr 04, 2020 6:40 pm
i have to flight controllers that need the power wires hooked up to them with xt60s i normally go to MSC to get it done but closed
wildblue30
Re: Soldering Job
Unread post by wildblue30 » Sat Apr 04, 2020 7:17 pm
The last time I went by there they were closed, but a sign on the door said they are still doing business and to contact them on their Facebook page. Apparently they are making arrangements to take orders and coordinate pickups. Try them on Facebook.
MAAC 85077
Ivan
Re: Soldering Job
Unread post by Ivan » Sat Apr 04, 2020 7:27 pm
i would but i am one of the many few that does not have Facebook , the gram, twitter and other crap like that
Re: Soldering Job
Unread post by bdg » Sun Apr 05, 2020 10:08 pm
What a great chance to try it yourself... really an easy process. Just need a soldering iron and some solder.... not sure what stores are open now but it really is not that daunting.... lots of YT videos to help as well as people here.
Ivan
Re: Soldering Job
Unread post by Ivan » Mon Apr 06, 2020 9:04 pm
small wires together im not to bad at but pdb's i just don't think my iron is hot enough can you guys point me in the right direction and how hot a iron (watts) i need
just got this one https://www.canadiantire.ca/en/pdp/well ... p.html#srp said 60watts on the package took it out and says on the iron 18watt
Re: Soldering Job
Unread post by bdg » Mon Apr 06, 2020 10:47 pm
I have a 60W. The one that you purchased suggests "equivalent to 60W". Perhaps equivalent on a small area?
You need enough power such that the heat recovery is adequate for when you contact a large "heat sink" such as the circuit board. Ideally, the temperature monitored / adjustable units are preferred where possible, but these can be more costly. I tend to like heating at 350°C or so, but your mileage might vary!
It's unfortunate about the isolation or I am sure someone would be able to help you out.
wildblue30
Re: Soldering Job
Unread post by wildblue30 » Tue Apr 07, 2020 1:03 am
Ivan,
I know you needed something right away, so I don't blame you for going to Canadian Tire. Just a heads up I got this 60W soldering iron from Banggood about a year ago for a very reasonable price. I am quite satisfied with it. Also, it is easy to find replacement tips for.
https://www.banggood.com/Mustool-MT223- ... ehouse=USA
Replacement tips:
https://www.banggood.com/10pcs-900M-T-B ... rehouse=CN
MAAC 85077
Re: Soldering Job
Unread post by retiredVTT » Tue Apr 07, 2020 2:18 am
Princess Auto have a 40W for $19, and a 60W for $23. but they are NOT adjustable. That's a neat feature with the Banggood units.
