Soldering Job
Got something to sell or trade?
Ivan
Re: Soldering Job
Unread post by Ivan » Tue Apr 07, 2020 7:20 am
ok guys thanks again will look into getting a better iron and will watch a few more videos not like im going anywhere anytime soon Be safe guys and thanxs
robcole1967
Re: Soldering Job
Unread post by robcole1967 » Fri Apr 10, 2020 1:16 pm
Ivan do you still need that soldering job done?
Ivan
Re: Soldering Job
Unread post by Ivan » Sat Apr 11, 2020 1:27 pm
going to wait a bit and try a little more practice did up some xt60s last night and its looking good
the-mailman
Re: Soldering Job
Unread post by the-mailman » Sat Apr 11, 2020 3:13 pm
Just remember to put the heat shrink tubing on the wire before soldering the connector on. It's really had to put it on afterwards.
Re: Soldering Job
Unread post by bdg » Sat Apr 11, 2020 8:27 pm
I've found that XT60s can melt with too much heat. EC3s can take a lot of heat as you are only soldering the connector outside of the plastic housing... but an XT60 is already embedded in the plastic shell. The solution? Make sure to attach the mating connector under the one that you are soldering. The extra heat sink and integrity has worked every time for me!
Ivan
Re: Soldering Job
Unread post by Ivan » Sat Apr 11, 2020 8:45 pm
thanks again guys getting a little better at it stay safe hope to see you all this summer
