Soldering Job
Soldering Job
any one up for a soldering job i dont mind paying im not in a rush and i can drop it off and pick it up
Re: Soldering Job
Ivan,
What do you need soldered?
MAAC 85077
Tarot 450 Pro V2, H-King Voltigeur, E-Flite Ultimate 2, BAe Hawk EDF, H-King Wargo MX2, E-Flite Timber X, E-Flite UMX Timber X, E-Flite UMX A-10, Eachine E160, Eachine E180, YX F180 V2, MJX Bugs 3
Transmitter: RadioMaster TX16S
Re: Soldering Job
i have to flight controllers that need the power wires hooked up to them with xt60s i normally go to MSC to get it done but closed
Re: Soldering Job
The last time I went by there they were closed, but a sign on the door said they are still doing business and to contact them on their Facebook page. Apparently they are making arrangements to take orders and coordinate pickups. Try them on Facebook.
MAAC 85077
Re: Soldering Job
i would but i am one of the many few that does not have Facebook , the gram, twitter and other crap like that
Re: Soldering Job
What a great chance to try it yourself... really an easy process. Just need a soldering iron and some solder.... not sure what stores are open now but it really is not that daunting.... lots of YT videos to help as well as people here.
Re: Soldering Job
small wires together im not to bad at but pdb's i just don't think my iron is hot enough can you guys point me in the right direction and how hot a iron (watts) i need
just got this one https://www.canadiantire.ca/en/pdp/well ... p.html#srp said 60watts on the package took it out and says on the iron 18watt
Re: Soldering Job
I have a 60W. The one that you purchased suggests "equivalent to 60W". Perhaps equivalent on a small area?
You need enough power such that the heat recovery is adequate for when you contact a large "heat sink" such as the circuit board. Ideally, the temperature monitored / adjustable units are preferred where possible, but these can be more costly. I tend to like heating at 350°C or so, but your mileage might vary!
It's unfortunate about the isolation or I am sure someone would be able to help you out.
Re: Soldering Job
Ivan,
I know you needed something right away, so I don't blame you for going to Canadian Tire. Just a heads up I got this 60W soldering iron from Banggood about a year ago for a very reasonable price. I am quite satisfied with it. Also, it is easy to find replacement tips for.
https://www.banggood.com/Mustool-MT223- ... ehouse=USA
Replacement tips:
https://www.banggood.com/10pcs-900M-T-B ... rehouse=CN
Replacement tips:
MAAC 85077
Re: Soldering Job
Princess Auto have a 40W for $19, and a 60W for $23. but they are NOT adjustable. That's a neat feature with the Banggood units.
