Need help finding a part
News related to anything RC
the-mailman
Unread post by the-mailman » Fri Apr 20, 2018 12:14 pm
I had to take one of my motors apart to remove some debris and lost the clip on the shaft. It flew away somewhere in my workshop. Does anyone have or know where to get an E-clip or C-clip to fit a 4mm shaft? I tried MSC and a few other places, but so far no luck.
JohnF
Re: Need help finding a part
Unread post by JohnF » Fri Apr 20, 2018 3:12 pm
I would think that Mighty Small Cars would have that item in stock
the-mailman
Unread post by the-mailman » Fri Apr 20, 2018 3:26 pm
JohnF wrote:I would think that Mighty Small Cars would have that item in stock
I thought so too but they only had 3 and 5 mm clips.
Unread post by retiredVTT » Fri Apr 20, 2018 3:43 pm
Bruce, is there room to put a "wheel collar" on the shaft to replace the clip...??
the-mailman
Unread post by the-mailman » Fri Apr 20, 2018 4:35 pm
retiredVTT wrote:Bruce, is there room to put a "wheel collar" on the shaft to replace the clip...??
I never thought of that. I'll look for one and try it. Thanks.
Unread post by retiredVTT » Fri Apr 20, 2018 4:56 pm
If you can get the size in "MM" I may have one in my box ....probably either 4mm or 5mm.
JohnF
Unread post by JohnF » Fri Apr 20, 2018 11:05 pm
I think I have a clip that might work for you. If the wind is not too high, I will be at SP on Saturday. If not, I will be at SP on Sunday morning then go to Shearwater for the indoor flying.
the-mailman
Unread post by the-mailman » Fri Apr 20, 2018 11:15 pm
Thanks everybody, but I found what I needed. I have a burned out motor for my Spitfire and it had a clip that was the right size. Should have checking my old junk in the first place.
