Cleanup after using CA debonder
- RonStuart
In changing the mounting tabs inside the cowling of my DHC-2 Beaver from a screw mounting system to magnet mounts, I had to debond three of the four new mounting tabs and will be re-installing them. The debonder did its job effectively but I am left with a mess of sticky, gooey residue. After trying more debonder, then alcohol, neither of which has been effective, it occurs to me that somebody more experienced than I probably has the answer to this cleanup challenge. Thanks in advance for your help. Ron
Ron Stuart
HEFA 116
MAAC 87976
E-Flite Piper Cherokee, E-flite DHC-2 Beaver
UMX Timber, Eagle 2, HOB Harvard
HEFA 116
MAAC 87976
Re: Cleanup after using CA debonder
Try methyl hydrate, you can get that stuff at Canadian Tire in the paint section. Not expensive, besides it works great on defrosting car door locks.
