Mark
lift has increased based on throttle stick position and battery consumed less by 300mah in five minutes.
I will keep them, sending you a payment tonight.
BYW I just use a small piece of silicon fuel line as a bushing to fit the 6mm holes on the 3mm shaft work great.
Jerry
Hexacopter Frame
- MarkL
Re: Hexacopter Frame
Sounds good.
I did a few quick tests today on my big hex. The 10X4 wood drew less amps than the 10X4.5 nylon props, but took a touch over 50% throttle to hover, so a bit more than the nylon, which was expected since pitch is less. The 11X4 hovered right at 50% and drew less amps than the nylon at hover but a bit more in flight. The 10" drew less amps overall but I'd like to keep hover at 50% or a hair under and with a bit more payload I think they would be too small. Didn't get a chance to try the 12"
They did seem to make more noise or perhaps just a different deeper noise than the nylon props.
I tried the fuel tube first thing this morning as well but my smaller motor shafts are 5mm so was too much, but 2 layers of heat shrink seems to fit great. quick and simple solution. I'll be testing them on the smaller hex next.
