Tri-Wii Copter (Grand Maximo)
- KrasherJack
Re: Tri-Wii Copter (Grand Maximo)
Another Rainy Day..
Some more progress, Motors and Controller installed.
Zoom..Zoom
- KrasherJack
Just did a weigh-in 1kg with Battery, motors and props..
Zoom..Zoom
Oh my, with those motors and that weight Jack it ought to go like a rocket!!! What are you going to use for a battery? I think you will probably need to put maybe two 3S-2200s in parallel to supply enough current especially if you let me test fly it
- KrasherJack
Just Had the maiden sorty, I need to change up the props...
8*6 bit on the low side...
Zoom..Zoom
- KrasherJack
10*6 Props installed now, also had to calibrate the ESC range, on the throttle, so they would arm, and run together.
Nice...
Nice...
Zoom..Zoom
I'm really surprised that 8x6 wasn't good enough with those motors Jack.
- KrasherJack
Yea, they were probably fine Rick, it was the ESC timing that was the problem.
I'll leave the 10*6 on for now, lotsa lift.
Jack
Jack
Zoom..Zoom
