Maiden - ICON and EFXtra
anything to do with foam or depron models
New postby bdg on Sun Apr 09, 2017 7:41 pm
I was able to maiden two planes this morning.... the ICON A5 UMX is the ultra-micro weighing in at roughly 100g and therefore is exempt from the latest TC rules, which only start at 250g. The ICON is long discontinued but I was able to find one NIB from a Freedom Hobbies in Fredericton (unfortunately not available locally). Free shipping. The link from Horizon: https://www.horizonhobby.com/ultra-micr ... y-pkzu2380
This plane flew absolutely perfectly in light winds and even in more moderate winds - where the windsock was straight out. The plane did not have enough power to slide through the wet grass (no wheels installed) but hand launched perfectly. Rolls, loops, level flight - fast and slow - it did it all very well. I was able to easily stay within the confines of the mowed area of the field but also ventured into normal circuits (closer) and could still see it okay.
I bet that the ICON would not handle any type of waves and the cover has ventilation which could also introduce water. I will be pulling the control board and will be dipping it in Corrosion X to hopefully mitigate issues with water in the fuselage.
The other plane that I maidened today was the EFXtra. This is reputed to be quick on 4S but I was flying on a 3S 2200mAhr battery. The plane was definitely a little "squirrelly" in the air and it was not up too long. Definitely tail heavy so I need to revisit the COG. URL: https://hobbyking.com/en_us/faster-larg ... tra-1.html
Unfortunately, I brought it in fairly hard and the prop broke - apparently a fairly common issue with this plane. No other damage other than the cowling filling with mud. I thought that I had some spare props but they are reverse pitch and therefore will not work in the planned configuration with the spinner. The other props that I do have will not fit on the spinner.... but that is minor. I hope to try it again soon after I work out the COG.
Fun times :-)
See you at the field!
Return to Foamies
