EPP FPV plane from HK
anything to do with foam or depron models
eyeinsky
Unread post by eyeinsky » Mon Jan 02, 2012 11:11 am
The Standard configuration is not the best for fix wing operation due to the dimension and orientation of gyros.
I mounted the board vertical arrow straight up this resulted in the need to swap channels to maintain proper gyro orientation.
The throttle channel must be connected to the both KK board and the ESC, I suggest a Y cable.
Arming is done by keep throttle at idle and Rudder over hard or in my modified configuration elevator down. If the board does not arm reduce throttle trim till arming can be achieved.
Useful Links:
http://lazyzero.de/en/modellbau/kkmulticopterflashtool
Where I got my board:
http://www.ebay.ca/itm/260881453731?ssP ... 221wt_1048
I've seen them little cheaper, but make sure you get the USB loader too. Later you can buy them seperatly but don't buy the HK ones with only 4 output ports.
black board 5.5
Tutorials:
http://www.youtube.com/watch?v=qhwIkf16 ... _embedded#!
Latest update to the KK control HK EPP FPV aeroplane.
