Help w AC/DC Charger
- Canuck4ever
OK - I'm back into the hobby after 8 years and now we have NiCd and NiMH batteries, LiPo cells and LiFe packs (heavier than Lipos but better?).
From reading various forums, it appears Lipos are the way to go but they have to be charged under supervision (exploding problem?)
That said, if I wanted charger for NiMH (DX6i) and Lipo batteries/cells what would be a good charger? Looking for AC and DC input charging cabalility
Any inputs or insight would be appreciated on which charger is preferred (approx $100.00)
If I'm off the mark with batteries, feel free to correct me
PS: I could not find a specific spot for batteries or chargers, my appologies in advance if this is in wrong forum
Marc "Coyote" Cayouette
Remember.....if it fits back in the box you bought it in - it likely won't fly again!
- karlpenney
Re: Help w AC/DC Charger
For NiMH, use the DX6i's built in charger, or one of the chargers from Eneloop, Energizer, etc.
For Lipo, check out the Cellpro Multi4.
Revolectrix used to have an AC/DC power brick specifically for it, but I don't see it on their new website. You can get one locally for around $25 though.
Karl
Karl
- Canuck4ever
schooner2000 wrote:I use the AC6 http://www.nitroplanes.com/thac6smbalic.html
Works great and is AC and DC
Tks all - the Thunder AC6 looks to be exactly what I was looking for. As for transmitter charging, bring spare charged set
If you use it with Hyperion batteries you will need the balance adapter as the one with doesn't work with hyperion. Also make sure to get an adapter with whatever battery connector you plan to use, Deans, XT60, etc. It comes with some but not those.Canuck4ever wrote:schooner2000 wrote:I use the AC6 http://www.nitroplanes.com/thac6smbalic.html
When looking at a charger look at the maximum watts. The AC6 mentioned above has a max out of 50 watts. A 3 cell LiPo at 11.1 volts means a max charge rate of about 4.5 amps. A 6 cell at about 22 volts means a max of about 2.25 amps. Often the descriptions of units can state X amps, but that output is often at lower cell counts.
Having a unit that has an AC connection is not that great an advantage. I use a converted Computer power supply for my 12 volt supply in the house with 2 pairs of female banana jacks. Others in the group do as well. I have a permanently connected Cigarette lighter adapter in my car with Banana jack females soldered on the wire ends. I have various chargers all with male banana jacks on them. I have several chargers, some of which are no longer available so I will not mention them.
The most useful one I have found for LiPos is this one for 24.95US
http://unitedhobbies.com/hobbyking/stor ... ge_Capable
It can charge 2 2cell packs at a time or 1 3 cell or 1 4 cell. No LCD no messing around. Just pick the charge rate and go. I use it for all my batteries down to 600 mah. They are inexpensive enough that you can get 2 or 3 for less than some of the more complex units. Sometimes charging 2 or 3 batteries at a time is very useful.
The next order I place with Hobby King will include another of these.
If the Tx you have uses 8 cells then Hobby King has LiPo packs for transmitters, that may replace the NiMh pack. It is important to put voltage dropping diodes between the pack and the Spectrum Tx if you use a 3 cell pack. Using LiiPo will give you hours of run time and reduce the self discharge, so the Tx is always ready to fly.
- Canuck4ever
And just when I thought I had it all figured out
