Cleanup after using CA debonder
New postby RonStuart on Wed Oct 04, 2017 9:22 pm
In changing the mounting tabs inside the cowling of my DHC-2 Beaver from a screw mounting system to magnet mounts, I had to debond three of the four new mounting tabs and will be re-installing them. The debonder did its job effectively but I am left with a mess of sticky, gooey residue. After trying more debonder, then alcohol, neither of which has been effective, it occurs to me that somebody more experienced than I probably has the answer to this cleanup challenge. Thanks in advance for your help. Ron
Ron Stuart
HEFA 116
MAAC 87976
E-Flite Apprentice S, E-flite DHC-2 Beaver
Avistar 40 Mk II, Eagle 2, HOB Harvard
RonStuart
Re: Cleanup after using CA debonder
New postby JohnF on Thu Oct 05, 2017 9:15 pm
Try methyl hydrate, you can get that stuff at Canadian Tire in the paint section. Not expensive, besides it works great on defrosting car door locks.
JohnF
Return to Workshop
